CHECK ENGINE, GAS SMELL & BEYOND
Old Dec 25, 2007 | 08:17 PM
DURANGED's Avatar
DURANGED
Default CHECK ENGINE, GAS SMELL & BEYOND
HEY THERE..
SO I HAVE A 2000DURANGO SLT 4 X 4 THAT I RECENTLY POSTED HAD A CHECK ENGINE LIGHT ON AND A SMELL OF GAS IN THRU THE AIR VENTS INSIDE THE TRUCK-SO NOW A LOCAL MECHANIC CHANGED MY OXYGEN SENSORS, ADDED NEW SPARK PLUGS(MINE WERE BLACKENED AND SHOT)AND ALSO ADDED A NEW AIR FILTER-THE TRUCK NOW APPEARS TO BE RUNNING FINE AS THE CHECK ENGINE LIGHT HASNT COME BACK AND THE GAS MILEAGE(WHICH WAS HORRIFIC-MORE THAN USUAL!!)IS BACK TO NORMAL-I STILL AM HOWEVER EXPIERIENCING THAT SLIGHT SMELL OF GAS COMING THRU-IS THIS SOMETHING THAT WILL DISSAPATE IN TIME OR IS THERE SOMETHING WRONG THE MECHANIC MISSED? ANY IDEAS?
Old Apr 20, 2009 | 11:07 AM
carbophat's Avatar
carbophat
I know this is an old thread, but I have the same gas smell coming through the air after changing my plugs as well. Help?
Old Apr 20, 2009 | 06:10 PM
Durango03's Avatar
Durango03
Im gonna take a shot in the dark, but could it be because your plugs were so bad before and now the vehicle is getting too rich? I know some cars you can disconnect the battery and reset the computer and have it learn your driving style. Just my $.02
Old Apr 20, 2009 | 06:13 PM
schusterjo's Avatar
schusterjo
Could be a vacuum leak causing it to run lean. (just taking a shot in the dark)
Old Apr 20, 2009 | 10:49 PM
hydrashocker's Avatar
hydrashocker
Reset the PCM. Here are instructions:
Engine Code Index (Check Engine Light?)
Old Apr 21, 2009 | 01:50 PM
carbophat's Avatar
carbophat
Thanks guys, i'll check this out..
Old Apr 27, 2009 | 01:23 PM
carbophat's Avatar
carbophat
Okay, I have done the restart Hydra suggested and I still have that gas smell. Therefore, I am assuming I need to be looking at vacuum lines now?
Old Apr 28, 2009 | 04:43 PM
RockGuardedDak's Avatar
RockGuardedDak
STOP RIGHT THERE! make sure there isnt an exhaust leak under the hood, or close to under the hood. THIS WILL CAUSE A GAS FUME SMELL IN THE CAB, but other than that, im clueless lol
Old Apr 28, 2009 | 07:43 PM
hydrashocker
Shop could have not tightned a plug enough or installed the wrong plugs. Let the PCM fully reset as I instructed. Most likely you are burning rich and it will take time for the computer to figure it out. About 48 miles and 12 starts. Do as instructed in the post.
You can check all vacuum lines leading into the air hat because people forget to reconnect them.
The last thing you can do is to find out what spark plugs the shop installed? What motor are we working on?
