abs and brake lights on
Old Dec 31, 2007 | 03:49 PM
memphisdropzone's Avatar
memphisdropzone
Default abs and brake lights on
hey guys my abs and my brake lights are on but some times it doesnt come on,and before you tell me the rear wheel sensor already change,and reset computer and light still comes on and sometimes while driving when i go to it the brakes and she makes a funny noise and starts pulsating and suggestions
Old Dec 31, 2007 | 04:06 PM
durangeddurango's Avatar
durangeddurango
Default RE: abs and brake lights on
pulsating is normal when the abs engages.slippery roads,etc.as it goes for the lights front wheel speed sensors (if equipped)could be bad,need a scanner to see the wheel speeds,air in the lines,ebrake pedal partial engaged, mis adjusted e-brake switch,
Old Dec 31, 2007 | 04:31 PM
memphisdropzone
well it pulsates even when its dry it just does it and at the same time it makes that funny noise
Old Dec 31, 2007 | 05:16 PM
durangeddurango
i think you need a wheel speed senor u need to plug in a scanner and see what the wheel speeds are.
Old Dec 31, 2007 | 05:35 PM
n8ech's Avatar
n8ech
MDZ:
First off, do you have RWABS, or 4WABS.If yours is one of the rarer D's with ABS at all wheels, I would check the front sensors. There should be a serated ring attached to each halfshaft that lets helps the computer determine wheel speed. If that ring is dirty, or cracked and moving around it would cause the issue you are seeing. As said, you also might have a bad sensor.
If you only have the rear wheel version (I call it useless), then could be the computer or the pump unit under the hood.
Don
