Brake Problem
Old Jan 11, 2008 | 11:08 PM
cjholm's Avatar
cjholm
Default Brake Problem
I have a 98 Durango. The ABS and Brake light stay on and the brake pedal goes the whole way to the floor. Any ideas what the issue is??
Old Jan 11, 2008 | 11:14 PM
durangeddurango's Avatar
durangeddurango
Default RE: Brake Problem
check for a leaks, you have air entering the brake system somwhere.
Old Jan 11, 2008 | 11:15 PM
Duranged408's Avatar
Duranged408
Get the code checked out. As for what it could be theres a list full
Master cylinder, lines, air in the lines, low fluid, rear brakes not adjusting
*** Side note --- Whenever the ABS stays lit after the initial 2 second check on the dash, the ABS system is shutdown until the problem is fixed.
