Durango Issues
Old Dec 4, 2011 | 05:53 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by candy man
how do i reset computer on 2003 on dodge durango. i have disconnected neg cable for 5-10 minutes even overnight. truck starts ok but have no lights .what am i doing wrong. i have tried turning key on and off but still no luck,can anybody outthere help?????
To reset your engine codes / PCM:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery.
Start but do not hit the throttle. Idle for about 10/15 seconds then turn off.
Restart the truck and drive as usual. It will take at least 12 starts and 48 miles to fully retune the computer. Hard Codes leave a shaddow for 40 full cold starts.
