heater
Old Jan 21, 2008 | 03:56 PM
almand01's Avatar
almand01
Default heater
i was just reading the durango blower switch thread and it sounds kinda like my problem. all my power setting blow fine, they just will not blow hot air. i have had people say that it might be the thermostat. but could the blower switch be causing that possibly. not having any heat at this time of year is definately not fun in the mornings. so if anyone has any suggestions it would be wonderfull
thanks, Reid
Old Jan 21, 2008 | 06:20 PM
n8ech's Avatar
n8ech
Default RE: heater
almand:
What does your temp gage read??? As long as it is in the 190-200 range when warmed up the t stat should be ok. When was the last time you flushed your cooling system? If its been three years or 36k, then it is time. Could also be a blocked heater core which seems to be happening a lot lately with the older D's.
Don
Old Jan 21, 2008 | 07:32 PM
almand01's Avatar
almand01
Default RE: heater
well i got in a wreck about 4 months back and had to get a new radiator, so my cooling system should be fine i would think. but my heater didnt work before i wrecked either so it isnt because of the accident. i will have to check the temp tomorrow morning when i drive it.
