01 Durango Door Panel Removal?
Old Feb 2, 2008 | 06:42 PM
emi's Avatar
emi
Default 01 Durango Door Panel Removal?
Hi All...
When I was putting up my driver side window I heard a noise and the window wouldn't go up. So now the window is stuck open and actually falling down... Any idea how to remove the door panel? Is there a diagram somewhere? Thanks a lot.
Old Feb 2, 2008 | 10:10 PM
jbusta's Avatar
jbusta
Default RE: 01 Durango Door Panel Removal?
It shows how to remove the door
http://www.craigcentral.com/durango/speakers.asp
Old Feb 3, 2008 | 08:49 AM
emi's Avatar
emi
ORIGINAL: jbusta
Looks great... thanks a lot. will try today.
Old Feb 3, 2008 | 11:51 AM
rchiefari's Avatar
rchiefari
emi - your window regulator broke (which is very common in these). I would get one before you take the door panel off. They're a little tricky to get in - not much room in there. Takes about 45 mins with a helper (to hold the window)
Old Feb 8, 2008 | 12:36 PM
emi's Avatar
emi
thanks for all the help... I finally took the door apart. It is the regulator. ordered it from partsamerica for $83 shipped... Dealer wanted $270 plus install... so it will be quite a saving. thanks again.
