rear wiper fuse
Old Feb 3, 2008 | 06:01 PM
Steeltown67's Avatar
Steeltown67
Default rear wiper fuse
hi
does anyone know where the fuse for the rear wiper is on my 98D ??
it looks like i have a short an it is draining the battery
thx
Steeltown
Old Feb 3, 2008 | 06:10 PM
hydrashocker's Avatar
hydrashocker
Default RE: rear wiper fuse
Should be eather under the hood on the drivers side half way down or open the driverside door on the dash on the side when you look in.
Old Feb 3, 2008 | 06:17 PM
Steeltown67
found the fuse in beside the drivers door just say's ' wipers '
is this all the wipers ??
kinda need the fronts up here now with this white stuff on the ground
steeltown
Old Feb 4, 2008 | 09:17 PM
Durango03's Avatar
Durango03
Just pull it and see if yur front still work, My guess...NO. Worse comes to worse disconnect the wire to the motor from behind the rear hatch panel.
