New Dodge Durango owner, have question
I have recently bought a 99 slt without an owner's manual, and I cannot locate the rear wiper fuse. I have looked in the fuse box between the driver's door and the dash, as well as the fuse box under the hood near the battery. Could it be on a fusable link somewhere? The switch on the dash will not activate it, so a fuse would be the first logical step in making it work again. Any help?
First it should be on the same fuse (# 4 block 20 amp) as the wipers on the dash.
Also pop out the switch and check for power and see if that helps. Might just be a bad switch.
When you do pop the switch out make sure its not drawing power all the time. Could have been disconnected on purpose to seel beacuase of killing the battery. Just a thought.
