cylinder 1 misfire
Old Feb 18, 2008 | 12:12 AM
dirt_trac_racer_80jr's Avatar
Default cylinder 1 misfire
the check engine light recently came on in my 03 durango ....when i plugged it in to the scan tool ...i got a code that said clyinder 1 misfire ..this is consistant with how the engine feels ..it idles a lil rough...but doesnt seem to lack any power ...wat do u think could be my problem ...i consider myself to b a highly qualified mechanic but this one has me stumped ...point me in a direction please
Old Feb 18, 2008 | 12:18 PM
OneBadKota's Avatar
OneBadKota
Default RE: cylinder 1 misfire
Is it the 4.7 motor?
I've read before of an issue and the coil/wire plug had to be replaced.
Old Feb 18, 2008 | 02:25 PM
i believe it is ...it doesnt say on the engine anywhere..all it says is dodge magnum V8...hopefully that helps ...i checked all the documentation the car has with it and i couldnt find the enigine size anywhere...could it possibly be an injector problem ....or possibly plugs and wires?
Old Feb 18, 2008 | 02:34 PM
hydrashocker's Avatar
hydrashocker
It is under the hood on the ID sticker. There should be three. It is usually located on the passenger side on the hood or the front clip in small writing on the top or bottom of the sticker. It should also have your spark plug gap info.
We really need to know your engine size first to answer your question. If you can't find the info just post a good pic of the motor.
OneBadKota
It's called a coil over. On the 4.7L there is one for every plug.
Old Feb 18, 2008 | 07:52 PM
n8ech's Avatar
n8ech
The easy way to know is look for a distributor. The 5.9 motor does have one, and the 4.7 does not.
Could be a bad plug, or a bad coil. How many miles on the rig?? The oem Champion plugs are only rated to 30k. If you are much beyond that, they are toast and should be replaced ASAP.
A quick reminder that the heads are aluminum, so you will want to change the plugs when the heads are cool. A dab of no seize on the threads won't hurt either.
Don
Old Feb 20, 2008 | 02:56 AM
aight well ...it turned out to be a bad coil ...thnx for your help
