Fuel Rail and Line AGHH
Old Feb 23, 2008 | 09:44 PM
ANemic_SLuG's Avatar
ANemic_SLuG
Default Fuel Rail and Line AGHH
OK so in working on my Durango I noticed the fuel rail was indented and the line came off rather easily with my fuel line tool. Well it looks like the previous owner didn't have a fuel line tool. So what can I do to repair the line, or where can I get a replacement line? Also the fuel rail is indented a little and wondering who has replacement fuel rails as well or am I stuck with fishing through the pick-a-part.
Thanks
Old May 22, 2008 | 01:44 PM
hydrashocker's Avatar
hydrashocker
Default RE: Fuel Rail and Line AGHH
I would go to the dealer. Now if you were removing it to install larger injectors then you can install other recommendations.
Pick-A-Part is ok but, if you install one the the other owner ran crapy gas in all the itme then there could be rust inside and the rust will brake off and plug the injector. If you do this, flush the hell out of em first!
