Odd problem
Old Mar 8, 2008 | 06:23 PM
duogs's Avatar
duogs
Default Odd problem
Recently has developed a problem when trying to fuel my 1999 Dodge Durango. It will not accept more than a dribble of fuel while fueling ,so takes me almost 20 min's to fill the tank. Seems to be some sort of blockage. Can't see anything down the filler neck. If anyone has any ideas what could cause this, please let me know.
THX
Old Mar 11, 2008 | 09:50 PM
hydrashocker's Avatar
hydrashocker
Default RE: Odd problem
There is a rubber garment that connects the filler to the tank. It isusually on an angle and after time it can pinch off causing this problem. Look up under the driver side rear wheel right behind the tire. I believe it is a dealer part but a parts store my have it.
Easy fix.
Old Apr 10, 2008 | 09:21 PM
duogs's Avatar
duogs
Thanks for your help. Turns out that after taking off the filler hose I found a small round piece of cardboard from a bottle of injector cleaner lodged in the filler neck and partly blocking the tube. Easy just had totake it apart.
Old Apr 11, 2008 | 10:26 AM
hydrashocker
Nice to see you got it out and back on the road driving and fueling away.
