I've developed what appears to be a leak where the water pump mounts to the engine block. This is on a 2000 Durango with the 5.9L motor. It is bone stock with 85k on the odo. Is this a common problem for these cars? Do these cars have a history of the gaskets between the W/P and engine block leaking?
While we're on the topic of cooling systems, what about the stock radiators for these vehicles? I believe that the tanks are plastic and the cores are metal. Is there also a history of the plastic tanks eventually cracking or developing leaks at the interface between the tank and the metal core?
Thanks in advance.
Thanks in advance.
No No No.
It might just be a seep hole in the water pump and they often make it look like the gasket. Either way just replace the pump. NEW ONLY!
Dude 85K on a water pump is pretty good. Although **** does happen, I would say you got your money's worth.
Well, as it turns out, I discovered after a closer look that it was the freeze plug on the front of the block (next to the W/P) that was leaking. Pulled it and installed a new one.
Also replaced the radiator with a new one. Cost was $140 from www.radiatorswarehouse.com. Very happy with the fit of the aftermarket rad.
