2000 5.9 durango overheating
Old Mar 15, 2008 | 10:43 PM
rmac10's Avatar
rmac10
Default 2000 5.9 durango overheating
i have replaced water pump and tsat still overheating even though resevoir full seems not to be pulling water into block any feedback appreciated
Old Mar 16, 2008 | 07:08 PM
n8ech's Avatar
n8ech
Default RE: 2000 5.9 durango overheating
Rmac:
Did you let it idle and purge the air from the system while topping it off as the air comes out?? Will it overheat atidle, or only when you are running down the road? You may have a clogged radiator. Has the cooling system been flushed and maintained properly??
Don
