Engine stallls
Old Mar 16, 2008 | 04:22 PM
RFMendez's Avatar
RFMendez
Default Engine stallls
I have an 03 durango and sometimes I pull out of my driveway and it dies. Or sometimes it dies if im at a stop and then step on the gas it dies or hesitates from time to time. Just asking for suggestions. I put it on the computer but nothing is registering.
Old Mar 16, 2008 | 06:59 PM
hydrashocker's Avatar
hydrashocker
Default RE: Engine stallls
General tune up with regular Champion Plugs, Cap and Rotor with brass tips, OEM wires or MSD.
Also fuel pump may be going out.
Old Mar 19, 2008 | 03:04 AM
invadertim1's Avatar
invadertim1
I am having almost the same problem with my 98 SLT... One thing I was told to check, were the bolts on the intake manifold, throttle body, and valve covers for vacuum reasons... (after verifying that the fuel pump was ok, all the relays were good, oil pump was clean, replaced battery and plugs)... when i checked the bolts, they were VERY loose. I tightened them down to torque specs as per the chiltons manual and my truck has been running quite a bit better. I still have some bugs to work out but that was definately one of the problems.
hydrashocker gave me some great advoce about my problem..some of those suggestions might help you too.
https://dodgeforum.com/m_1224174/tm.htm
