deleted
Old Mar 20, 2008 | 11:48 AM
spartacus's Avatar
spartacus
Default deleted
deleted
Old Mar 21, 2008 | 09:53 AM
n8ech's Avatar
n8ech
Default RE: 2001 durango-abs diagnostics
Spartacus:
First off, what kind of problems are you experiencing? We need to know if you have the rear (or 2 wheel) ABS which was standard on the Durangos, or the 4 wheel version.
At any rate, the sensor for the rear is mounted on top of the differential. If you have the 4 wheel version, there should also be a sensor at each front knuckle that works in conjunction with a star wheel or reluctor that sits on your halfshaft.
More info is needed before we can point you in a direction.
Don
