greasing hub
Old Mar 27, 2008 | 01:54 PM
r235's Avatar
r235
Default greasing hub
can you grease a hub by putting grease into the anti lock sensor hole on the hub.
Old Mar 27, 2008 | 02:44 PM
duff73's Avatar
duff73
Default RE: greasing hub
From what I know of the 4wd hubs, they are a sealed unit, and as such, when the bearings go, the whole hub has to be replaced. If you can find someone with a press to disassemble it, replace the bearings and grease them when you put new ones in; then you don't have to replace the hub. You can buy a new hub for about 110 IIRC, and they should only charge you an hour per hub.
Old Mar 27, 2008 | 06:30 PM
hydrashocker's Avatar
hydrashocker
They are a sealed bearing. You can buy the bearing if you have a press. If not the whole hub needs to be replaced.
