2000 5.9 4x4 Tranny Problem
Old Apr 9, 2008 | 12:42 PM
marine25's Avatar
marine25
Default 2000 5.9 4x4 Tranny Problem
I've searched thru alot of previous posts but wanted to post a new thread because my problem is not identical to the others.
From a complete stop while in drive, i had my foot on the accelerator and i could hear the engine reving a little but it took a sec or 2 to start going. Shifting in between 1st and 2nd was also not normal. All the other gears seemed fine.
I stopped and shut off the vehicle, checked transmission fluid with vehicle running, and it was full.
Then when i started goign again, it shifted perfectly fine all the way home. Then today it did it again.
Any ideas? THe truck has the engine light on and i haven't been able to get it to a shop yet to read the codes.
Please help...
Thanks
Old Apr 9, 2008 | 01:29 PM
dwhisnant's Avatar
dwhisnant
Default RE: 2000 5.9 4x4 Tranny Problem
Being new here, I've been scrounging around for answers too. I can't exactly help with the tranny, but I ran across this that may allow you to read your own codes without a scanner seein it's a 2000+. Wish this worked on a 1999.
https://dodgeforum.com/m_1014921/tm.htm
Check it out and post the codes too, these guys seem to know about everything.
Old Apr 9, 2008 | 02:23 PM
marine25's Avatar
marine25
Wow... thanks i went right out and tried it and the codes popped up instantly
now where is this speed sensor located ?
P0720 Output speed sensor circuit malfuntion Is this in the tranny?
p0138 02 sensor high voltage
p1682 metering oil pump malfunction
Old Apr 10, 2008 | 01:11 PM
marine25's Avatar
marine25
Thanks to everyone that helped.
I replaced the transmission output sensor Code P0720and all is back to normal.
