Durango Serpentine Belt pulley problems
Old Apr 13, 2008 | 06:20 PM
ejherrmann's Avatar
ejherrmann
Default Durango Serpentine Belt pulley problems
We have a few questions concerning the pulleys used with the serpentine belt on our '99 Durango.
We have a loud squeak when driving and we're fairly sure it's the A/C pulley, we have already replaced the Idler pulley.
My Questions are.............
Is it possible to change just the bearing on the A/C pump pulley?
Where can I find a breakdown of the pump to get a part number?
Is the tensioner supposed to have spring tension on it at all times? I am able to use a wrench to remove tension to remove serpentine belt and it doesn't "spring back" it just stays put. Is that correct? It does apply pressure to the belt if I turnthe tensionerCCW and it seems to hold.
Old Apr 13, 2008 | 08:27 PM
daddy_bear_21's Avatar
daddy_bear_21
Default RE: Durango Serpentine Belt pulley problems
It would appear that your tensioner pulley is bad, as it should pring back one you release the pressure on it. I would also venture to say that the squeak is related to the same pulley. As for the A/C pulley issue, you might be able to replace the pulley itself, but I am not sure.
Old Apr 14, 2008 | 12:41 AM
OneBadKota's Avatar
OneBadKota
I would replace the tensioner(it should have tension at all time)and would bet it fixes your problem.
Most issues with a belt squeak are either the idler pulley, tensioner or the belt itself.
I've thought of it to be the A/C before and it was not.
.02
