humming noise
Old Apr 19, 2008 | 02:45 PM
merc2k's Avatar
merc2k
Default humming noise
I have a '99 durango slt that has a loud hum or rubbing noise in the front passenger side. It occurs from about 5mph-25mph and then stops. It also stops when the brakes are applied. Has anybody heard of this? any help?
Old Apr 19, 2008 | 05:12 PM
Dango85's Avatar
Dango85
Default RE: humming noise
If it stops when you press the brakes, then I would start there. Sometimes, the brakes on my 2001 make a little noise at certain speed ranges, but then stops once the brakes are engaged. It could be a warped rotor touching the pad.
It could be something totally different, but it'd be worth a look.
Old Apr 20, 2008 | 05:59 PM
hydrashocker's Avatar
hydrashocker
A hum is usually assossiated with a wheel bearing going out.
