error code no bu 5
Old Apr 22, 2008 | 06:06 PM
Keri0323's Avatar
Keri0323
Default error code no bu 5
I just bought my durango saturday, on the way home it cut off, it's done atleast once everyday since, it will crank back up after a few mins. while its down it say no bu 5, any ideas what this code is?
[/align]
Old Apr 22, 2008 | 08:25 PM
hydrashocker's Avatar
hydrashocker
Default RE: error code no bu 5
No idea on that code. Try to get it to Auto Zone or something and have the code read. This is were you can desifer the code. Engine Code Index
Sounds like a computer problem. Might be a relay as well. If ithis is your problem look under the hood on the drivers side for the fuse bx. OEM usually puts an extra relay in there. Try switching them out and see if it cures your problem. If it does just replace the relay. They (for the most part) are the same.
