2000 missing Durango
Old May 2, 2008 | 06:16 PM
00DD's Avatar
00DD
Default 2000 missing Durango
i have a 2000 5.9L Durango with about 150,000 miles. I have been getting a code from time to time that is Missing Cylinder #4. The first time I replaced the plugs and wires and it went away for about 10,000 miles. The light came on again, I checked the plug, it was cracked so I replaced it and the CEL went out again and stayed for another 10,000 miles or so. Well, the light came back on, the plug seemed fine but I replaced it anyway. This time the code did not go away. It is always Cylinder #4. Any ideas?.....thanks for the help.
Old May 2, 2008 | 06:24 PM
Durango03's Avatar
Durango03
Default RE: 2000 missing Durango
which plugs are U using?
Old May 2, 2008 | 06:31 PM
00DD's Avatar
00DD
i don't remember the number, but they are the Champion plugs that are on the sticker under the hood
Old May 3, 2008 | 08:17 AM
hydrashocker's Avatar
hydrashocker
Have you replaced the cap and rotor yet. Do so with brass contacts not the cheap one.
Wires should be OEM from the dealer or MSD 8.5mm only.
I bet you cracked it by accident. How do the plugs look when pulled out and also what gap are you using?
Old May 5, 2008 | 08:55 AM
00DD's Avatar
00DD
Thanks, I'll order a cap and wires from Mopar and try that.
Old May 7, 2008 | 11:03 AM
hydrashocker
I think it will be easyer to do it that way for ya.
