Is there a way to tighten the Side mirrors?
Old May 13, 2008 | 10:52 AM
2001OffroadRam's Avatar
2001OffroadRam
Default Is there a way to tighten the Side mirrors?
Is there a way to tighten the side mirrors on a 98 durango? Mine shake so bad when i'm driving that you can't even see out of them.
Thanks
Old May 13, 2008 | 03:16 PM
440shadow's Avatar
440shadow
Default RE: Is there a way to tighten the Side mirrors?
the mirror or the housing? if its the housing just remove the door panel and tighten the bolts holding the mirror on
Old May 13, 2008 | 03:26 PM
2001OffroadRam
Its the mirror inside the housing that seems loose on both sides
Old May 19, 2008 | 10:39 PM
naturecannon's Avatar
naturecannon
my mirror was doing the same thing. Fell off few weeks later and was hanging from the wires. I just got some good epoxy at the depot. Still shakes minor but not like before.
Old May 20, 2008 | 07:58 PM
hydrashocker's Avatar
hydrashocker
OUCH!!!
I don't think just epoxy is going to hold. I would rebolt it.
Old May 21, 2008 | 05:01 PM
Mean Green's Avatar
Mean Green
Also make sure your tires are balanced and check your driveline to rule out any damage. Those 2 things will shake the crap out of you and the 1st thing you'll notice is a shaky mirror.
