xylene added to gas
Old Jun 25, 2008 | 09:32 AM
DRO318's Avatar
DRO318
Default xylene added to gas
I have ben adding xylene to my gas and Ifeel more power and about a mile or two in the tank. Xylene is one of the major componets in fuel injection cleaners along with accetone, but I don't recomend using accetone because it will only greatly decrease your mileage. I put 20 bucks of gas in the tank Along with 3 to 3.5 ounces of xylene. This is also great for you HHo DIY's. It will help you lean out the mixture of air and gas when you use the map sensor inhancer.
Old Jun 27, 2008 | 03:16 PM
marshman's Avatar
marshman
Default RE: xylene added to gas
wow... haha i've only used xylene for paint removal purposes when i didn't have any thinner handy
how much would you reccomend in a full tank?
Old Jun 27, 2008 | 10:05 PM
DRO318's Avatar
DRO318
Well the mix ratio is diff for everyone because we all live in different states with different ratios of gas and ethonal. Plus the fact that it may differ from engine sizes. Personally I use 20 bucks equal to 5.5 gallons. Now on the water4gas website it says use 3 ounces for every 10 gallons but I saw no diff at allin that mix. as a matter of fact i started to return the xylene to sherman williams, but instead I added another 3 ounces and about a gallon of gas. Then I saw the results that I was expecting. Remember this is not the same feeling you get when you add a supercharger, but this is very noticeable if you pay attention to your "D". Keep in mind that there are different qualities of gas and there are diff mixtures of ethonal and gas. I have tried diff gas stations to test the mileage on 20 bucks. Where I liveValero, Walmart, and Diamond Shamrock are good for me.I would do it like this drive your "D" around trying to pay attention to the power you already have. Let your tank get to 15 miles left in. Add maybe3 ounces of xylene, thenadd five gallons of gas. If you feel no diff after close to half the way through your five gall, then add another ounce or two. The worst that I have experienced when adding too much was my gas burned alot faster. If that happens add a glloon of gas. fFnd the right mix.
[sm=feedback.gif]
