HOW TO FIX STRIPPED CALIPER BOLTS
Old Jul 2, 2008 | 08:28 AM
oldschool5's Avatar
oldschool5
Default HOW TO FIX STRIPPED CALIPER BOLTS
STRIPPED CALIPER BOLTS? GET A HELI-COIL KIT #5546-9 (9MM X 1.25) A 23/64" DRILL BIT AND SOME LOCTITE #27100 ( RED HI STRENGTH THREAD LOCKER). ONCE YOU GET THE WHEEL/ ROTOR
ETC. OUT OF THE WAY, SHOULD TAKE ABOUT TEN MINUTES OR SO PER HOLE TO DRILL/TAP/ AND INSTALL NEW THREAD INSERT. WORKED OUT VERY WELL FOR ME.
Old Jul 2, 2008 | 10:46 AM
hydrashocker's Avatar
hydrashocker
Default RE: HOW TO FIX STRIPPED CALIPER BOLTS
This was done before and worked.
