Camshaft/Crankshaft position sensor replacement on 2000 (4.7) Durango?
Is it advisable to replace the crankshaft position sensor when replacing the camshaft position sensor on the 2000 4.7L Durango?
Wouldn't start,got trouble code indicating camshaft position sensor problem.I replaced the camshaft sensor and the engine now starts but runs very rough and will not idle without my foot on the accelerator.I have seen a couple of posts that advised changing both of these if one is faulty.
Any reasoning behind this?
Retrieved codes P0340/P0725/P1391 using OBDII scan tool.
Does a bad camshaft sensor cause the crankshaft sensor to malfunction or vice-versus?
