413 truck motor
Old Jul 16, 2008 | 12:10 AM
MyDurigable's Avatar
MyDurigable
Default 413 truck motor
Im doing a straight axle swap in my 99 durango. Now I have accuired a 413 truck motor out of a 76 motorhome. I was wondering if the bellhousing bolt pattern is the same as the 360 in the Durango?
Old Jul 16, 2008 | 06:30 PM
jeff66's Avatar
jeff66
Default RE: 413 truck motor
Been a long time since I seen a 413, The 413 is a big block, itwon't bolt up to your 360 bellhousing (which is a small block) as far as I know.
Old Jul 16, 2008 | 10:59 PM
hydrashocker's Avatar
hydrashocker
Not to mention the computer.
Big and Small Block so they won't work.
Old Jul 17, 2008 | 03:51 AM
MyDurigable
The computer is coming out. Severe wiring problems. The dealer told me that the intire harness has to be replaced at a cost of 1200 dollars. Minimum the intake will be changed to a four barrel, found the intake already. Never thought about the big block small block. Dumb over-sight. Thanks for input
