oil pan change
Old Jul 19, 2008 | 07:55 PM
anthonyfear's Avatar
anthonyfear
Default oil pan change
can anyone tell me how to change pan on 98 durango 4x4?
I know i need to lift engine - but how much? and what needs to be disconnected first? I don't have to lift the whole thing out do i?
Old Jul 20, 2008 | 02:19 PM
hydrashocker's Avatar
hydrashocker
Default RE: oil pan change
You should just have to disconect the motor mounts and lift the motor if it is a 5.9L or 5.2L enough to remove the pan. You will need to remove the skid plates if equipted.
Old Nov 16, 2008 | 11:45 PM
russgraus's Avatar
russgraus
im not quite sure on a 98 with a 5.2 or 5.9 but it was a real pain on my '02 with a 4.7L. i couldnt get enough clearance between the pan and the fron axle with just the motor mounds disconnected, i also had to disconnect the tranny mount. lol. so glad i already had the 3" body lift on it. other wise not sure if it would have cleared without yanking the motor lose.
Old Nov 17, 2008 | 08:03 AM
Duranged408's Avatar
Duranged408
X2, plus trans
Old Nov 17, 2008 | 11:03 PM
hydrashocker
You have to remove the front axel and mounts up the &*$%^&*
Your better off pulling the motor.
