MSD Blaster SS Coil
Old Aug 13, 2008 | 12:59 PM
SnowDigger's Avatar
SnowDigger
Default MSD Blaster SS Coil
I purchased a MSD Blaster SS for my 5.9l 2003 Durango.
I also was reading a post about the Blaster SS damaging a PCM:
http://www.msdignition.com/forum/showthread.php?t=2017
I wonder if the coil could be installed without using the factory wiring. Just connecting it to an ignition powered positive and a chassis negative like I would if there would be no PCM. Would that work if leaving the factory coil and wiring in place as well? I thought I may just cap the coils post for safety, install the Blaster and connect it to the distributor, done.
Is there a better way of doing this?
Old Aug 14, 2008 | 11:02 AM
nim81's Avatar
nim81
should have got MSD p/n 8228 and ACCEL ignition coil adapter harnesses
if you want to run the blaster ss coil you need the blaster $$$ ignition and all the goodies
Old Aug 14, 2008 | 11:37 PM
hydrashocker's Avatar
hydrashocker
First of all I can't even find the SS coil that goes to your rig. I don't even think they make them yet so I wonder why they wouldn't take it out????
Here are some part #'s
https://dodgeforum.com/forum/showthr...light=ignition
