Diff fluid change
Old Aug 19, 2008 | 08:24 AM
hydrashocker's Avatar
hydrashocker
Really???
What diff do you have?????
We need to use modifier for LS. Premature failure can occure.
Old Aug 19, 2008 | 09:30 AM
gr8scott72's Avatar
gr8scott72
Originally Posted by hydrashocker
Really???
It's the 9.25" diff with no LS with 3.27:1 gears. (Until tomorrow. It'll have 4.56:1 gears after that.)
Old Aug 19, 2008 | 03:36 PM
n8ech's Avatar
n8ech
Hydra:
The only Gen 1 trim package that included Limited Slip as standard was the R/T.
It was optional for the rest, and strangely was not part of the tow package unlike Ford and GM.
BTW, the Gen 2's 4x4s were not offered with it at all. The 2wd models could be had with it however.
Gr8tscott:
The only factory offerings for gears were 3.55 and 3.92.
4.56 is a pretty deep gear. Are you going with bigger tires as well to offset that???
3.55 to 4.56 is a pretty radical change especially with stock wheels. 3.92 to 4.56 will be less so, but still quite a change.
Don
Old Aug 19, 2008 | 05:47 PM
gr8scott72's Avatar
gr8scott72
Originally Posted by n8ech
Gr8tscott:
You're right. It's a 3.55:1.
I am towing 6,000 lbs every day (mostly in town diving) and need all the help I can get.
I will probably go to the next bigger/taller tire when these die.
I'm looking forward to it being a radical change.
Old Aug 19, 2008 | 06:50 PM
n8ech's Avatar
n8ech
Scott:
Here is some baseline info from a fellow Gen 2 2wd owner that made the swap from 3.55 to 4.10 for the same reasons you are. Note that these numbers are for the stock wheels.
Numbers with Stock 3.55 Ratio Numbers with New 4.10 Motive Gears and Trac-Loc
50 MPH = 1500 50 MPH = 1730 55 MPH = 1700 OD
60 MPH = 1600 60 MPH = 1850 (2850 RPM in Tow/Haul)
65 MPH = 1730 65 MPH = 2000 (expected 2100)
Don
Old Aug 22, 2008 | 12:19 AM
hydrashocker
Originally Posted by M Shark
I don't mean to jack the thread but how do you tell if you have an LSD? I have a 2002 SXT. I'm also contemplating on changing my rear diff fluid.
Well See here:
http://www.newcartestdrive.com/revie...&ReviewID=3184
What year and engine are we working on. It seems that I was wrong and I was thinking in reverse. LS was the difference not regular.
