band adjusting screw for 99, lost
Old Aug 26, 2008 | 06:22 PM
texasliam's Avatar
texasliam
New Member
Default band adjusting screw for 99, lost
My mechanic says that somebody has put in the wrong band adjusting screw into my 99 durango. Does anybody have a source for this part?
Old Aug 27, 2008 | 08:53 AM
hydrashocker's Avatar
hydrashocker
Dealer.
You need to get the model of the trans.
Old Aug 27, 2008 | 03:40 PM
texasliam's Avatar
texasliam
New Member
where will that information be?
Old Aug 28, 2008 | 10:51 AM
hydrashocker
What is your motor?
What kind of shifts do you have on the T-case?
4X4 or 2WD?
Old Aug 30, 2008 | 09:30 AM
texasliam's Avatar
texasliam
New Member
1999, 5.9L, 4x4, automatic, 2 gear shifters
Im not sure what "What kind of shifts do you have on the T-case?" means
thanks
Liam
Old Aug 30, 2008 | 10:34 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
what positions ex awd 4hi 4lo 2wd ect one ofthem has like 5 different settings i think and the other has 3 but jsut look and read off what it has then let us know
Old Aug 30, 2008 | 03:29 PM
texasliam's Avatar
texasliam
New Member
Thanks for explaining
5 positions: 2H, 4PT, 4FT, N, 4L
and it has the famous droping band anchor, which is pretty much what this is all about.
Traveling mechanic found the anchor in the pan. He put it back in and it lasted for a couple of weeks then the trany failed again. He then said he thought the adjusting "screw?" was to short and that's why the anchor fell out. That is asuming its fallen out again. So I would like to have a look myself. That involves taking of the pan, then the valve body I asume. Any tips on getting the valve body off without exploding springs and *****? And if the "wrong adjusting screw" theory is incorect, what else can cause the anchor to keep dropping out?
thanks in advance.
Liam
