Durango
Old Sep 2, 2008 | 05:21 PM
kenzpen2000's Avatar
kenzpen2000
Default Durango
I have a 2001 durango 4x4. while driving horn will beep, and lights will flicker about every 5 minutes anybody have any ideas.
Old Sep 2, 2008 | 07:40 PM
n8ech's Avatar
n8ech
Congrats:
You have joined the time for a new CTM (Central Timer Module)club. It is a dealer part that is located behind the kick panel next to the drivers feet.
Part will run you ~$280, and the install labor will be another $150-200 dollars.
You can install the part if you want, but the dealer will have to program the unit. It will require them having all your remotes present to do the job right.
Don
Old Sep 3, 2008 | 06:28 PM
kenzpen2000
Default central timer
is the keyless entry the only this that has to be programed
Old Sep 3, 2008 | 09:56 PM
n8ech's Avatar
n8ech
Ken:
Not sure if the keyless is the only issue or not. At any rate, you could try it snd see what happens.
I don't think it would hurt anything.
Don
Old Sep 5, 2008 | 03:01 PM
kenzpen2000
Default central timer module
ok the new ctm (central timer module) is installed and everything works < i tried programing the key fobs and it would not enter the programming mode i did it just as the owners manual says but no luck any help would be greatly appreciated.
