Coolent leak
Old Sep 21, 2008 | 06:20 PM
MONEYMIKECEO's Avatar
MONEYMIKECEO
Default Coolent leak
Have a 2003 durango,i have coolant leak,driver side at the bottom of the refill resevoir ,any ideal what it might be
Old Sep 22, 2008 | 10:18 AM
hydrashocker's Avatar
hydrashocker
Consitering the heat that is assosiated with the coolant I'm not too sure epoxy resin will work. I know that www.rockauto.com sells them for about $22 and they ship it right to your house.
Old Sep 22, 2008 | 10:40 PM
n8ech's Avatar
n8ech
MM:
When does the leak occur?? Does it happen when running, or only when shut off? Aree you seeing alot, or just a drip??
Could also be the tank seal on that side giving up the ghost, or the upper hose leaking where it attaches to the radiator, and running down the side.
Don
Old Sep 23, 2008 | 12:42 AM
OneBadKota's Avatar
OneBadKota
The easiest way(for me anyways) Go to Autozone, rent the Coolant System Pressure Tester and pump it up to the rated PSI of the system. I've found any leak this way.
.02
