squeaky front end?
Old Sep 23, 2008 | 09:45 PM
whitepony99's Avatar
whitepony99
Angry squeaky front end?
Hi guys,
I have a 1999 dodge durango and the driver side of this thing squeaks real bad. When you are driving and braking it squeaks. When you turn the wheel it squeaks. So I went ahead and push down on the front end driver side. When I push down it squeaks and also coming back up it squeaks. What does this sound like to you guys? I thought it was the front shock but am unsure
Old Sep 24, 2008 | 08:25 AM
hydrashocker's Avatar
hydrashocker
Most likely it is the sway bar bushings. They are a piece of cake.
You can lower the bars and lube them with some Teflon grease or if they are bad replace them. There are 2 sets. (outer and inner) The outer consists of 2 bolts and the inner I believe is one bolt. You want to lower them without raising the vehicle.
Polyurethane bushings are the best but OEM should work fine. I would do this first before replacing the shocks.
Old Sep 24, 2008 | 08:56 AM
DRO318's Avatar
DRO318
+2 on that Hydra
In my case the sound came from the control arm bushings. yeah they were shot.
Old Sep 24, 2008 | 08:51 PM
whitepony99
But the squeal only comes from the driver side does that make sense?
Old Sep 25, 2008 | 09:13 AM
hydrashocker
Like I said,
This in normal and it is very easy to do with basic tools and maybe 30 min max. Not to mention CHEAP!
Try this first then go to the shocks which depending on driving habits as to which one's you should go for?
Old Sep 29, 2008 | 11:59 PM
03DurangoR/T's Avatar
03DurangoR/T
my d did the same for a month then it went away. never squeeked since and its been 4 months. weird
Old Oct 7, 2008 | 11:45 PM
durango360's Avatar
durango360
I just finished putting in the electric fan and now I can hear all sorts of squeaks and creaks when the fan is not running...My D is really quiet now (except for the front end squeaks..). I think I will follow hydra on this one and replace the bushings and see if that helps. oh yeah, the flowmaster I just picked up should help with that silence issue...
Old Oct 8, 2008 | 12:15 PM
DRO318's Avatar
DRO318
Cool, got ah flowmaster huh...
If option 1 does not work try spraying some white lithium grease on all the control arm bushings. Good luck
Old Oct 9, 2008 | 06:38 PM
hydrashocker
Exhaust helps the sounds of the truck....LOL
Although it does a crapy job on fuel mileage becuse ya like to hear it.
Old Oct 9, 2008 | 10:08 PM
DRO318's Avatar
DRO318
Yeah man when I head mine at the light, it sets something off in my head. other car/trucks try to pas by me floorin it so I let it ripp. MPG's always go down.
