Part No for PCV Valve Pipe
Old Oct 23, 2008 | 10:56 AM
Chris_Gorham's Avatar
Chris_Gorham
Default Part No for PCV Valve Pipe
Hi,
Following on from my over maintenance of my 1999 5.9l D when I chopped the end off the hose leading from the PCV valve, traversing behind the throttle body and ending at the inlet manifold...
I now to replace this pipe...
Looked at Dodepart.com and I can't identify it and local dealer here also not certain.
Does anybody know the part number for this thing...??
Thanks...Chris
Old Oct 23, 2008 | 09:16 PM
DRO318's Avatar
DRO318
Dude just get a vac tube the same size as your PVC, and you be just fine. The Manifold and the PVC fittings should be the same
Old Oct 26, 2008 | 02:20 PM
hydrashocker's Avatar
hydrashocker
It's a formed-fit hose and is dealer item only.
Old Oct 27, 2008 | 09:22 AM
DRO318's Avatar
DRO318
it will work either way
Old Oct 27, 2008 | 12:36 PM
hydrashocker
I think the size is about 1/2. The thing is where it installs theres that bend right as it goes into the air hat and being so close to the firewall it would be hard to get-r-done aftermarket but I think it could be done. I think the OEM version would be better. The other thing you could do is get a barb fitting and maybe put an extention on the old tub.
