AC/HEATER Problems
Old Oct 25, 2008 | 10:58 AM
darinadkins's Avatar
darinadkins
Question AC/HEATER Problems
1998 Durango. Heater & AC doesn't blow through dash vents. Only blows through window defrost on top of dash. Also, heater & AC is not working. The fan blows good.
Old Oct 26, 2008 | 02:26 PM
hydrashocker's Avatar
hydrashocker
Sounds like a vacuum leak. Check the hose that goes into the firewall to the dash. Look inside the engine bay. Drivers side on the cab firewall where the throttle body cord comes through and you'll see it. Double check the connection above this before the brake booster off the "T".
Old Oct 27, 2008 | 09:18 AM
DRO318's Avatar
DRO318
+2 a vac leak
