3" Body Lift, 99 durango, 4wd
Old Nov 19, 2008 | 01:44 AM
DurangoDog1624's Avatar
DurangoDog1624
Default 3" Body Lift, 99 durango, 4wd
Hey, i have a 3" body lift (performance assesorys) that im about to hook up on my 99 durango 4wd. Is there anyone who has done this that can warn me about any problems ahead of time? Thanks.
Old Nov 19, 2008 | 08:27 AM
Duranged408's Avatar
Duranged408
-You will have to have the 4wd shifter cut then with the supplied extension welded in.
-You may want to lube up the steering shaft at the steering box a couple times before you put in in the extension.
-If you have a K&N FIPK you will have to adjust it/plan on going different CAI due to lifted fender (a smaller filter might work)
From what i remember, i started off checking for frame/body connections- first is removing the 4wd shifter then searched for grounds/couple in front, removed the gas hose/cut to put in extension, removed front/rear bumpers
Lifted 1 side at a time (this was by myself) can be a little tricky with the body tipped/alignment of bolt/threads. Loosened the fan shroud.
I cant exactly remember but i think i had to flip the lower rad hose.
Take your time, use common sense, follow the instructions, use loctite and a torque wrench..
