Alarm system disconnect
Old May 18, 2017 | 01:59 PM
unkelfester's Avatar
unkelfester
Originally Posted by 1fast84
Nealeyandjon I know you posted this like 7 years ago but I wanna say thanks!! I was stranded at Walmart and I seen your post and did what you said and boom my Durango fired right up!
99 Durango security mine still doesn't have a green/orange at drivers kick panel!
Old Jun 20, 2017 | 11:37 PM
unkelfester
mine still won't start!
Old Oct 29, 2017 | 08:02 PM
ZipperStar's Avatar
ZipperStar
Talking
Originally Posted by nealeyandjon
The FACTORY ALARM DISARM WIRE IS
lt. green/orange - , Located at a the
black plug in the drivers kick panel.
Once Located, splice into this wire with
a simular guage wire, and put it to
a solid chassis ground. This terminates
the alarm functions entirely.
If you want to use the alarm again all you do is remove the spliced wire
un hook your battery let it sit over night and hook it back up
This info comes from three different alarm system installers in killeen, Tx
Not sure how you know that, but it worked for me and my 99 Durango. May you have a great year..
Old Apr 11, 2019 | 09:05 PM
ZipperStar's Avatar
ZipperStar
lt. green/orange |-|, Located at a the
I did just that with my 99 Durango and the security light still flashes, and is somehow connected with the engine light, because sure as heck when you turn off the ignition and the security light flashes and charm dings in an off beat timing, the next time the engine is started the engine light is on again til I disconnect battery and go through the same process again, on the first or second ignition off cycle. Im 62 years old and nothing but mechanic all my life so throw it at me and I'll give it a go. I can't figure it out! Frustrating, and I can't drive with an engine light on. It's against everything I've lived for.
Old Apr 30, 2020 | 04:30 PM
Adrian Castillo's Avatar
Adrian Castillo
My dodge journey keeps on die on me
