Transmission Error Code after tranny shop?
I have a 2001 Durango 5.9 4WD... The transmission was overheating and lost overdrive around June of this year ... Took it to the tranny shop and they replaced several solenoids.. I believe one was the overdrive lockup solenoid .. They replaced a total of 4..
After all this I had the same problem .. overheat and then wouldn't go into overdrive (Trans Temp would come on) After the 2nd visit to the tranny shop I started getting the P1740 Manufacturer control Transmission code
I looked thiscode up and it looks like it is realated to the tcc or o/d solenoid..
Shortly after I started getting these and the tranny still overheated I replaced the Transmission oil cooler for a bigger aftermarket one...
It was plugged and I have driven over 5,000 miles and no problems at all out of it ...
I still get the error code with Check Engine Light every other day ..
Any idea why I would get this error and the tranny is doing ok ? I have had this code come up for the last 6 months ... I reset and it comes back in about 100 miles or 2 days ..
The shop may have used the wrong tranny fluid and that causes all sorts of problems like this. I am speaking from experience on this one. My tranny was rebuilt at AAMCO and they used ATF + 3 which is no good on our transmissions. It needs to be + 4. You should go back to them and check to see what kind of fluid they used on it.
I was running Royal Purple in it before and had no problems .. I asked the guy to atleast put synthetic back in it .. so who knows .. I wonder if I do a fluid and filter change if that would help the code or is there damage done?
Thanks
Thanks
01, 2001, charger, code, codes, control, controlled, dodge, durango, error, fault, manufacturer, p1740, ram, transmission, transmissionn
