Amp Wire. where to run it Thru? (02 Durango)
Old Jan 3, 2009 | 10:34 PM
cvc7chris's Avatar
cvc7chris
Default Amp Wire. where to run it Thru? (02 Durango)
those out there with amps..where did you run your wire thru? i've got a pretty damn thick amp wire i'm looking for a place to run. i don't want to run thru the door because it doesn't shut the door right plus it bends the wire or w/e
so...thru were? i'm also trying to avoid drilling holes
Old Jan 3, 2009 | 11:30 PM
Durango03's Avatar
Durango03
I popped it thru a grommet that was already on the firewall. Take a metal coathanger and start poking from the inside. I ran it along the door sill all the way to the back and thru the floor compartment. NEVER Run your wire THRU or AROUND the DOOR! I have seen Many fires caused from this!
Old Jan 4, 2009 | 01:12 AM
cvc7chris's Avatar
cvc7chris
i'm doing that tommorow. i just ran it thru the door for now (it's 1 in the morning and i'm beat!) and i'm gonna try that grommet thing you said
i only saw the hood latch cable grommet i'm not sure if that's the one or not
but i don't ever know if i've got a metal coat hanger..(so rare these days)
