2 Problems with the D
Old Jan 15, 2009 | 08:43 PM
BigRedMachine00's Avatar
BigRedMachine00
Default 2 Problems with the D
I've had a clunking under the passenger side floorboard for the past week or so. Got under the truck and I snapped my lower mounting bolt for the shock. Bolt snapped flush with insert in the lower mounting arm. The bolt has about an inch sticking out the back side where I could put some vice grips on and hopefully turn it out. Do you think I have a better chance of threading it back out, or continue to tighten it and with it having no head it should pull through?
Posted a topic about my locks not working about 10 days back, got no replies so I'll try again. Locks on the truck will unlock fine but will not lock using the master switch or key fob. When trying to lock I can hear a clicking coming from the glovebox. Any ideas? What I did notice is with it being freezing here in Chicago the locks will never work when I first start the truck. After driving around and the truck warms up they worked fine. This is hit and miss though, some days it works fine, some days after the truck warms up, sometimes not at all.
I've done alot to my D from reading other topics posted here and it's saved me alot of time and money. I don't get to visit as often as a I like but every time I do I learn something new. So any thoughts you guys have would be greatly appreciated - Thanks
Old Jan 15, 2009 | 09:12 PM
pat28mcanada's Avatar
pat28mcanada
if there is enough room and no burrs to keep it from going through i can't see why you can't take it out from putting it all the way through
Old Jan 15, 2009 | 09:31 PM
Mean Green's Avatar
Mean Green
#1 whichever way looks easier and #2 sounds to me like the CTM.
Old Jan 15, 2009 | 11:16 PM
hydrashocker's Avatar
hydrashocker
#1.... A picture says a thousand words.
#2.... It might be a problem with the drivers side lock control multi swich or the CTM.
Old May 19, 2010 | 09:19 AM
thorze's Avatar
thorze
Dammit BIGRED, PLEASE post a follow up!!!!!!!!! I to have just snapped the driver's side lower bolt on my shock and am looking for the correct bolt size and thread pitch??? Please post a follow up on this thread with the juicy details THANKS!!!
Old May 19, 2010 | 03:54 PM
hydrashocker
Good luck thor!
Just take it in to a hardware store and get a new one of grade 5 or better.
