re: abs and brake warning on
Old Jan 21, 2009 | 10:01 PM
14vanhalen's Avatar
14vanhalen
Default re: abs and brake warning on
I changed the rear sensor and both light are still on....a mechanic (a 1500 owner) told me that if just the abs comes on it is nothing major..but if the abs and brake are on its big like wiring or in the abs comp and his did the same and he unpluged the cp and the lights went out he has no abs but he's good with that so ....were is the abs computer located ..under dash or under hood?
Old Jan 21, 2009 | 11:46 PM
Mean Green's Avatar
Mean Green
The PCM controls the ABS function.
Old Jan 21, 2009 | 11:50 PM
schusterjo's Avatar
schusterjo
still could be the speed sensor on the tranny. Getting any codes?
Old Jan 22, 2009 | 09:22 AM
14vanhalen's Avatar
14vanhalen
The dodge dealer tells me speed sensor has nothing to do with it...I may just change to see if it does help ...do I change both speed sensors on the tranny?
Also had no speedo and p0500 came up but the next time i started the d up it was fine and the abs comes on when driving {brake pulse}
Old Jan 22, 2009 | 09:24 AM
14vanhalen's Avatar
14vanhalen
Also had no speedo and p0500 came up but the next time i started the d up it was fine now abs comes on when driving (brake pulse)
