Large Tires
Old Feb 21, 2005 | 05:15 AM
TheGoose446's Avatar
TheGoose446
Default Large Tires
It is about time for me to get new tires for my 2000 Durango 4x4. I have worn down the stock 235's thank god. I would like to put new tires on there that are much larger with out having to buy new rims. Would a 32x10.5x15 work on the truck? Or if possible what would be a bigger tire I could buy? What suggestions can you offer on the brand of tire I should invest in?
Old Feb 22, 2005 | 01:50 PM
Lianimal's Avatar
Lianimal
Default RE: Large Tires
My stocks are 31x10.5-15's. I'm not really sure what the rim size translates to so I'm not 100% you'd be able to go bigger.
As far as type is concerned, I researched like crazy to find the Goodyear Fortera HL's I'm using now. I do drive all on road so they were a good choice for me and an unreal upgrade to the Wranglers that were original.
What type of driving do you usually - on road or off?
Old Feb 22, 2005 | 09:27 PM
robust57's Avatar
robust57
32x11.5x15 is the largest tire you can put on a stock D. I run that size of BFG's mud terrain and have some rubbing.
235 doesn't tell me what size your tires are that's actually the width of the tire the second number is the ratio height for the tire when using metric.
