03 Keyless Entry/Tire question
Old Jan 29, 2009 | 09:23 PM
Trophyhunter07's Avatar
Trophyhunter07
Default 03 Keyless Entry/Tire question
Hey guys I bought a 03 4x4 SLT Durango today and it has the power windows and locks and all but it does not have any remotes.Is there anyway I can check to see if it has keyless entry if I just find somewhere to buy the remotes or ?? I pulled the carfax and it was a repo so maybe it had it and they just didnt get the remotes? And also I want to putt BF Goodrich A/T's on it what is the biggest I can put on there with no rubbing problems? THANKS Oh also does anyone know somewhere good to get the remotes if it does have keyless entry?
Old Jan 29, 2009 | 11:47 PM
hydrashocker's Avatar
hydrashocker
31X10.5 LT 15 tires are the biggest.
What you need is a "key Fob". Search for it in this area and you'll find a lot of info on it.
You can get key fobs at the dealer or ebay just make sure if you buy 2 you get the same encription code for both so they both work.
Old Jan 31, 2009 | 11:44 AM
Mean Green's Avatar
Mean Green
As long as your D has keyless entry your local dealer can program your fobs for you. I would have them program only one of the fobs. IIRC it is about $75.00 and once you have one fob that works you can program more fobs to your D with the programmed one.
