Axel support
Old Jan 30, 2009 | 11:10 PM
DurangoDog1624's Avatar
DurangoDog1624
Default Axel support
Ive noticed that a common problem with putting big tires on durangos is breaking the axel. So ive been looking into this and i was wondering if theres anything you can hook up on your truck to support your axel better and keep it from cracking? I know you can probably go to an axel shop and buy a special off roading axels but there so expensive. Is there a way to work around this?
Old Jan 31, 2009 | 11:58 AM
Mean Green's Avatar
Mean Green
Can you weld?
Old Jan 31, 2009 | 05:37 PM
Duranged408's Avatar
Duranged408
No way other that a full sas in the front..... Weld on that housing the beotch will be twice as fragile. I've tried braces taken from baja examples butstill not good enough... In the end if your doing anything that causes the front end to snap up then you should be thinking about a front axle and not IFS
Old Feb 1, 2009 | 04:34 PM
hydrashocker's Avatar
hydrashocker
FYI<------- Just don't do it in the first place.
Old Feb 2, 2009 | 08:22 AM
Duranged408
/\ Where's the team spirit? /\
I wanna see some carnage.... xD
