Upper Radiator Hose Leak
Old Feb 22, 2009 | 07:57 PM
Goudman's Avatar
Goudman
Default Upper Radiator Hose Leak
I am searching the Web attempting to find a source showing the parts skematics for a 2000 Durango 4.7L 4WD. I would like the skematics so I can choose the correct parts to fix a leak on the upper radiator hose. Does any one know where to find the factory part skematics to view online an determine the part numbers?
The leak on the radiator hose appears to be on the radiator side of the hose right where the filler cap assembly is. There are not clamps on each side of the filler assembly and it may all be one piece that was thermally fused to the hose. Either way, I wanted the sekmatic to determine the parts to order. Please help.
Thanks
Old Feb 22, 2009 | 11:52 PM
hydrashocker's Avatar
hydrashocker
Everything I see and also know there is suppost to be clamps on it to filler assembly. After time the hose can afix to the metal.
Old Feb 23, 2009 | 10:48 AM
Mean Green's Avatar
Mean Green
No clue on the schematic but if you contact your local dodge dealer they can let you know. I know I ended up paying $50 (dealer only item) when I broke the filler neck on the upper hose since the whole assembly must be replaced. This is on the 5.9 but I believe it would be just about the same. Check out www.rockauto.com they are a great source for all of your replacement part needs if you have the time to wait for shipping. I would have done that myself but I wouldn't have a ride then.
Old Feb 23, 2009 | 01:45 PM
hydrashocker
www.rockauto.com is awesome.
I did see that on the schematic that there were clamps.
