Won't start.
Old Apr 1, 2009 | 11:48 PM
cadavis's Avatar
cadavis
Default Won't start.
I tried to start my durango, and it didn't click, the dashlights didn't come on, and I am unable to turn my headlights on, started to jump it, the battery had spark and wouldn't jump. I had the battery tested but it came back good. All i can get is a buzzing underneath the steering wheel and if I open the glove box, the buzzing stops and a clicking in the glovebox begins. Shut it, the buzzing starts again. I then replaced the ignition switch, it didn't change anything. I got frustrated and started to jump it again. When I put the jumper cable on the negative battery terminal, the hazard lights all of the sudden came on, (its not connected to the other vehicle at all) so i tried to start it again and it worked. I took it for a spin around the block, turned it off, tried to turn it back on, nothing... repeated battery cable thing, lights came on again, vehicle starts. Yes the battery cables are tight. I don't understand it. What are your thoughts?
Old Apr 1, 2009 | 11:50 PM
DragonOfMadness's Avatar
DragonOfMadness
Yeah....Umm what year and motor is it???
Old Apr 1, 2009 | 11:51 PM
DragonOfMadness
And does it have an alarm system and what type?
Old Apr 1, 2009 | 11:53 PM
DragonOfMadness
Yeah,I bet you have a bad ground to the chassis=check em all...
Old Apr 2, 2009 | 12:01 AM
cadavis's Avatar
cadavis
98 durango, 5.2 v8 and yes it does have an alarm.
Old Apr 2, 2009 | 08:18 PM
hydrashocker's Avatar
hydrashocker
Sounds like a classic bad battery connection. Check the wires as well. Also check all grounds on the chassis.
