Drums locking up
Old Apr 8, 2009 | 10:45 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by DRO318
If I where you chequita68 the next time I drove would be back to the shop
I totally agree...........
Old Apr 9, 2009 | 10:03 AM
Facory's Avatar
Facory
Again, the brakes will not lock up after applying them only once at low speed against the engine. That' life - it happens to most of them.
Old Apr 9, 2009 | 11:19 AM
DRO318's Avatar
DRO318
I'd sit right there make sure you don't see any air bubbles coming out of the line when they bleed the brakes
Old Apr 9, 2009 | 11:06 PM
hydrashocker
I'll tell you this:
If you think it's just the pad to surface get that truck up on the freeway doing about 80 and push the E-brake in on an off ramp to slow you down. This will force the pad to surface of the drum and burn it in.
Be careful!
Because I don't drive my rig very much some times I'll get pitting from weather moisture that can lock up the front and this is how I get it burned off. You don't want to do it too much because it can glaze the pads.
Old Apr 9, 2009 | 11:39 PM
MAGIC84's Avatar
MAGIC84
While on this subject, and this is not for me but what about the possibility of swapping a 03 rear axle to earlier models, to get disc brakes?
Old Apr 10, 2009 | 09:24 AM
DRO318's Avatar
DRO318
They make rear disc kits bro
Old Apr 10, 2009 | 03:03 PM
chequita68's Avatar
chequita68
WOW... I do wish I was a guy at this point. I am going to take it back. It hasn't happened since, but my safety is important. Also are the drums suppose to look so rusty?
Old Apr 10, 2009 | 04:59 PM
hydrashocker
Yes the drums from the outside are supposed to look dirty. It's thin inside on the contact points that should be clear.
Take it back.......... And come back, we need female friends here.
Old Apr 11, 2009 | 12:17 AM
DRO318's Avatar
DRO318
My bad Lil lady
Old Apr 11, 2009 | 02:18 PM
chequita68's Avatar
chequita68
No problem Dro318 :-) . I like to visit these forums and get some advise so when I do go to the shops I kinda sound like I know what I'm talking about and MAYBE they'll think twice about taking me for a ride.
