just wasted $500 on ctm replacement
Old Apr 24, 2009 | 07:22 PM
jake1z's Avatar
jake1z
Default just wasted $500 on ctm replacement
truck has the infamous doors locking constantly and also dome light flashing/gate a jar problem while accelerating. took the truck in for a new ctm 500 bucks later still have the same prob... fought with the *** holes at the service center they they said the ctm was bad either way even though it didnt fix any of my problems. i unpluged everything from the rear gate and the door a jar/ dome lights still flash when i drive. its sooooo annoying. what if i cut the wire right before the ctm that goes to the switch?
Old Apr 24, 2009 | 07:47 PM
hydrashocker's Avatar
hydrashocker
Tell them to fix it!
Old Apr 24, 2009 | 07:53 PM
schusterjo's Avatar
schusterjo
Yup, thats what I wold be doing... Filling a complaint wit the better business bureau, asking for the district office number ext... I would not just stop at the word of ignorant service manager who's job is to rip u off in the first place.
Old Apr 25, 2009 | 01:12 AM
IndyDurango's Avatar
IndyDurango
You have two problems. The locks are easy for the dealer to fix and diag if they would have simply looked. It is TSB 08-023-03. The book provides them less than an hour to repair it, even out of warranty. That means it is a very inexpensive and cheap repair. 4 years after my fix, nada a problem since with it.
Here is your lock solution from my first forum post ever, anywhere:
http://www.durangoclub.com/forum/viewtopic.php?p=15861
I recall hearing about the light issue, but I can't put a finger on it. I'll look. In the meantime, pull the fuse and make that dealer refund your money after the above fix works for your locks.
IndyDurango
Old Apr 25, 2009 | 03:21 PM
hydrashocker
Posted: Thu Aug 25, 2005 1:41 am EDT
Your gettin old!
Old Apr 26, 2009 | 07:01 PM
jake1z's Avatar
jake1z
i thought the ctm is in the passenger side kick panel? i wanna cut the wire but all i see is the infinity amp
Old Apr 26, 2009 | 08:49 PM
IndyDurango
CTM = drivers side on yours if you see the amp on the pass side.
With that said, what are you messing with the (new) CTM for?
IndyD
Old Dec 9, 2021 | 08:53 PM
Rosa's Avatar
Rosa
Default Did you find a solution
Hi, I'm experiencing the same problem with my 2005 Dodge Durango. Did you find a solution?
Old Dec 16, 2021 | 11:13 AM
JeeperDon's Avatar
JeeperDon
Rosa, that story was 12 years ago.
Old Dec 23, 2021 | 04:58 PM
volaredon's Avatar
volaredon
I went to a u pull and got 3 ctm's from various Durango's for $10 each. Easy to swap out.
