Poor fuel mileage
Old May 13, 2009 | 05:00 PM
  #61
hydrashocker's Avatar
hydrashocker
Originally Posted by MAGIC84
Duranged, Stop with the madness, remember what happened last thread when you started posting these photos. You are o.k but Hydra and Indy get out of hand. LOL!!!
It's not my fault that my Durango likes to ram Duranged's lifted skirt......
Old May 13, 2009 | 10:29 PM
  #62
IndyDurango's Avatar
IndyDurango
I did it, read last post, next step is to quote other members. Indy, do I get a cookie?
Clap clap clap
Cookies for everyone!
Old May 13, 2009 | 10:40 PM
  #63
MAGIC84's Avatar
MAGIC84
Originally Posted by hydrashocker
Just go to the post you want to quote and on the post you will see on the bottom-right side the botton.
After it loads the post will be there in the right format. You simply erase the parts you don't want and under the final "
" line type your statement.
This will post your quote overhead and under it will be you statement.[/QUOTE]
NOW YOU TELL ME!!!
Old May 13, 2009 | 11:01 PM
  #64
IndyDurango
forget the button and type it like I taught you. That way you dont delete something you shouldn't and it not work.
IT ISNT HARD but it is getting old.
The reason your quote is screwed is because you have the {/quote} is in there twice because you were trying to quote it. CANT DO THAT because you are providing the computer with a command twice. HOWEVER the likelihood that happens is slim because how often is {/quote} in a quote in the first place? Never other than an instruction post like this. To confuse more, I have used { instead of a [ to keep it from happening and you COULD quote this post with no difficulties. The {/quote} will NOT be seen as a command because the { is different from the required [. Had HS not had that in his text, and had used an { for the illustration too, your quote would have been fine.
The computer is looking for specific commands. Just like if I TELL you to get me a BEER from the fridge and you brought back KETCHUP, you were given a command you didn't understand. { is not [ no more than a BEER is KETCHUP.
I'm done from here.
IndyD
Old May 14, 2009 | 07:32 AM
  #65
Duranged408's Avatar
Duranged408
Old May 14, 2009 | 05:58 PM
  #66
hydrashocker
NOW YOU TELL ME!!!
The post I did would not quote like you want it to because i was showing you the commands. Under normal use it will work fine.
I'm done from here.
I think you had too many beers!.....
Originally Posted by Duranged408
God your cheap. Is that the quarter slot?.....
Old May 15, 2009 | 02:49 PM
  #67
MAGIC84's Avatar
MAGIC84
CHAMPION TRUCK PLUGS came in today. They are installed and so far seem pretty nice, I can definitely feel the quicker response. Plugs I removed looked fairly normal and burn pattern was normal, but they are out and Truck plugs in. The #8 was not as bad to r/r as it was last time so that is another plus. Total time about 1 hour. Thanks for the help and suggestions guys. It is time for a fillup so I will post follow up when I get some mileage MPG results.
Old May 16, 2009 | 01:28 AM
  #68
IndyDurango
What is the Champion truck plug part number again? Photos?
Do they have them in ONE RANGE cooler?
TIA,
IndyD
Old May 16, 2009 | 01:50 PM
  #69
hydrashocker
CPN-4318 Champion Truck Plug Spark Plugs
Spark Plug, Truck, Flat Seat, 14mm Thread, .750 in. Reach, Resistor, Each
Today$2.95
I saw that question when I looked back and I'm sure they make a 1 step colder plug. Still from my experiance, I expect you are wanting to replace these in a style that runs close to the Autolites you like right? I don't aggree with this approach and if you look into what can happen with build up on the pistons you would probably aggree.
Old May 17, 2009 | 12:42 AM
  #70
IndyDurango
#4318
Today$2.95
Is that 4318 one range cooler? What is the other plug (proper range.) Yes, I'll only run the cooler set (as in the Autolites.)
As for buildup, I run a lot of things. Lucus stuff, acetone, seafoam, etc. I could probably eat off of the piston tops. Normal range pings. Cooler range doesn't on my motor. 201,000+ miles says somethings going right.
IndyD
