Injector Circuit Issue
Old May 6, 2009 | 05:38 PM
hydrashocker's Avatar
hydrashocker
Just give em a call. You can even rent them.
Old Dec 5, 2013 | 07:38 PM
Jim1993Dakota's Avatar
Jim1993Dakota
Originally Posted by unlvrebel
I've searched the forum without any clear cut advice so I thought that I would restart the conversation. The D recently threw the code P0207 - Cylinder 7 Injector Circuit fault. The symptom was a very short period of rough run - kind of like a missing cylinder. Makes sense to me. After the initial symptom the D ran fine. I cleared the code and went on my merry way. Eventually I received the code P0203 - cylinder #3. Again, same short-lived symptom and then moved on. This one actually cleared itself. I did not need to clear the code.
Here's the common thread to both codes - I was towing my 4000lb boat both times. My initial thought was that I must have had some gunk in the fuel tank that worked its way up and worked its way out. But why would that only happen under load? Any thoughts on this?
Thanks!
John
I have the semilar problem......#3 injector has a fault then while driving it goes a way to come back another day......What is it?
......james
Old Feb 22, 2014 | 12:02 PM
Jim1993Dakota
I have a problem:
Dodge Dakota LE, 1993, 5,2 Ltr. Engine Problem
Check Engine Light is On sometimes, sometimes engine runs ruff. then goes away.
Code Reader indicates codes: #27, #41 and #46
How do I fix that? Thankyou in advance. james
email address: imageone2009@live.com
